rough idle at startup
1989 Integra LS
My idle is rough at startup - with rpm needle bouncing around. However, once it is warm and I stop at a light, the idle is steady. I just did a tune up (new plugs, wire, dist. cap and rotor, and PCV valve).
What could be the problem? How do I test??
Thanks. I did a search and did find some hints.
Although idle is quite steady after warmup, it still tends to fluctuate a little bit, and a little bit more when I add a load: blinker, brake, fan.
Any additional hints with this information?
I don't think my car has those components.
My rpm needles bounces around erratically like there is a loose wire somewhere bouncing with the vibration of the motor. The speed is not loping.
Around my belt area I notice on startup a lot of noise - like loose bearings or bearings ready to go. The water pump has only about 15k on it. However, once warmed up the noise goes away. What can that be?
Have your alternator and battery checked, its possible that the ignition system isn't getting enough power, or a ground strap isn't connected.
If your hearing a squeeling sound, check the belt's tension & integrity.
If you're getting an inconsistant idle when the break is applied, could possibly be vacum also.
