What Aftermarket Exhaust?
Old 09-16-2006 | 07:14 PM
LateApex's Avatar
LateApex
Track Day Club
Default What Aftermarket Exhaust?
I have a 1994 GSR Sedan. It has 147,000 miles on it. Over the past year, I've installed new radiator, alternator (135 amp for stereo), head unit, woofers, tweeters, evap unit, ac compressor, plugs, wires, distributor, frt upper a-arms, frt sway bar and links, rear lower arms, rear links, frt and rr dampers, compensator arms and did all this with new hardware (no old nuts and bolts).
I think that the car easily has another 150 K miles in it. I only need to put a new chiming chain in in 15 K miles and replace the exhaust (catback).
I'm not basheful about buying OEM but wonder if there is a stock-like alternative at lower cost that's equal.
Thanks
Old 09-17-2006 | 01:11 AM
1turbodc2's Avatar
1turbodc2
got boost?
u can go with apexi ws2 or RSR both are very quite, and will give u more power then the stock exhaust system.
Old 09-17-2006 | 11:27 AM
2001TEGGSR's Avatar
2001TEGGSR
BTW: you're car has a timing belt - not chain. If your doing this yourself, make sure to replace the waterpump & tensioner while your at it.
and for the exhaust - you could always have a custom mandrel bent catback & muffler of your choice.
Old 09-17-2006 | 03:22 PM
g290ls's Avatar
g290ls
they call me tater salad
yeah any shop can help you help you out with your exhaust when i had my a ccord i did a custom cat back into a apexi n1 canister and it sounded and looked nice
