Quick Question: winter tire PSI
Old 09-13-2006 | 10:01 AM
RpG~^_^~LauRnO's Avatar
RpG~^_^~LauRnO
Default Quick Question: winter tire PSI
i have a set of 185/65/15 Yokohama Guardex 600 on my integra right now..
car has been stored for nearly 2 years. I am about to take it out for a few days just to have some fun.. and wonder what the correct PSI i should put on tires.. they seem to be really low right now.. i tried to put in 38PSI but still seem low to me.. any ideas???
Old 09-13-2006 | 11:37 AM
fastback's Avatar
fastback
http://www.tirerack.com/tires/tirete....jsp?techid=73
If it has been stored for that long, there are likely a lot of things that should be checked before you do any serious driving.
Old 09-13-2006 | 12:14 PM
Buyimports2's Avatar
Buyimports2
Probably the best thing to do is put the stock pressure in. You'll need to check it when the weather gets cold because the colder, condensed air will have less pressure.
If you choose to put more than stock pressure in there, make sure you never put more than 5psi less than the max psi listed on the tire.
Old 09-13-2006 | 03:46 PM
RpG~^_^~LauRnO
i have no idea what's the correct tire pressure for these tires??
any ideas??
Old 09-13-2006 | 03:47 PM
fastback's Avatar
fastback
It should say on the side of the tire.
Old 09-13-2006 | 04:07 PM
Buyimports2
any ideas??
35 psi front. 33 psi rear.
Old 09-13-2006 | 04:08 PM
Buyimports2
That's the max psi the tire can handle.
