turbo?
If your looking for a kit look into drag 3 kit or rev hard. Both use same size turbo which spools at the perfect rpm for hondas. The turbo size is t3/t04e. Perfect kits to start with and can be upgraded easily.
cusom is the way to go!
in the end, you will spend as much as buying a kit, but you will have better parts
for instance, i will have a better manifold, intercooler, and wastegate. plus instead of FMU i will have hondata... all for about $100 more than a drag kit.
Originally posted by MrFatBooty
T3/TO4E is the type of housing, not the size of the turbo. There are about 60 different sizes of T3/TO4E. The trim included with the Drag kits is too big to spool quickly (takes till about 4000 RPM which is not the "perfect" RPM by any means) but produces good peak output and good word-of-mouth advertising because of the high peak numbers.
