popping noise...
Old 09-07-2006 | 04:59 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Default popping noise...
Lately I have occasionally been hearing a single loud "pop" noise coming from the driver's side front wheel area. This usually only happens when I take right turns. I replaced the CV axle halfshaft about 4 months ago so I don't think it's that but I could be wrong. Balljoints possibly or something else? I also have a fairly loud droning noise coming from the same area when I'm on the highway. Thanks in advance for any help.
Old 09-07-2006 | 05:00 PM
99PreludeSh's Avatar
99PreludeSh
could possibly be ball joints. jack your car up a bit so the tire comes off the ground a couple inches, and take a crow bar under your tire and lift it up and see if it has any play or any popping noise.
I can explain a little better when I get home im off work cya later tater
Old 09-07-2006 | 05:23 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Since it occurs once per turn, I would bet on ball joint play over CV joint wear.
Also, the droning at highway speeds says wheel bearing wear to me. h:
Old 09-07-2006 | 06:41 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
My wheel bearing was god awfuly loud before I had it replaced, highway driving was torture. Feels like you have anew car once you get it fixed.
Old 09-08-2006 | 03:25 AM
R_Squared's Avatar
R_Squared
LEVEL UP
so how much can I expect to pay for a new set of balljoints/wheel bearings? Is this something I could do on my own?
Old 09-09-2006 | 08:32 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Anybody?
Old 09-10-2006 | 05:30 AM
g290ls's Avatar
g290ls
they call me tater salad
if you had a shop do it it would be like no more then 200 bucks at the most you could do it yourself but its a pain in the ass i have been told
