Reseting the ECU
Old 08-31-2006 | 08:52 AM
å's Avatar
å
åhhhhh
Default Reseting the ECU
I read the Integra FAQ and did a few searches but i couldnt find a way to reset my ECU..
I know it involved removing the negative battery terminal for like 1-2 minutes..
but what do i do after that? (ie turn the car on and idle for 15 minutes? hold at a certain RPM? go for a ride? )
Old 08-31-2006 | 08:53 AM
sherwood's Avatar
sherwood
I missed Sean
just disconnect it for a while and it willl reset.
if there is still a problem the CEL will come back on.
Old 08-31-2006 | 08:59 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
You've got it. Just disconnecting the battery for 2 mins will do the trick.
But if you have the factory radio, be absolutely sure to have the anti-theft code in hand before you disconnect the battery.
