KYB* Shocks
Old 08-30-2006 | 07:17 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Default KYB* Shocks
About a year ago, I installed a set of H&R Sports with KYB AGX Shocks. I overtightened the passenger front side shock and it broke so I kept the stock one in its place. One year later, at cruising speed around 70 Mphs or so I can feel vibrations and bumpyness, do you guys think that the stock shock in that corner has blown? Or is it some other problem? The thing is I also installed some ingall camber kits and if i change out the shock I would have to pay about $80 to get them realigned again, so I don't want to change it out unless I really have to. What are your suggestions?
Old 08-31-2006 | 02:34 AM
DaGip's Avatar
DaGip
4N2Ner
change it, i think i too will have to put back my tociko's over my Konis which have broke i think, left the car at my mechanics, will tell me tommorow, u should spend the $80 bucks or prob for that amount you might get an shock.
Old 08-31-2006 | 10:09 AM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
You should have replaced the AGX shock and still should. The suspension is designed to work together and when you change those dynamics, it can cause very adverse effects on your car including putting more stress on other components. Replace the AGX shock and then get an alignment when you can afford it. The camber alignment is not nearly as important as matching those shocks as long as its close. Uneven tire wear is much better than replacing suspension components.
Old 08-31-2006 | 11:39 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
What part broke? The strut or the retainer?
Old 08-31-2006 | 11:44 AM
Joe's Avatar
Joe
If you change your springs and dont change your shocks, they will wear out wayy faster.
Old 08-31-2006 | 02:09 PM
fastback's Avatar
fastback
You put one stock shock on the car with 3 AGX? Are you INSANE?
Old 09-01-2006 | 09:13 AM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Heh, its better than driving with 3 shocks ^^
Old 09-01-2006 | 11:16 AM
fastback's Avatar
fastback
Not by much.
