A few questions...
I suggest OTS spring rates, especially considering: a) you don't know what spring rate you want, b) the roads suck total ass in Socal, and c) I am assuming this is a daily driver that doesn't want comfort to suffer as a result of a higher rate.
Yea your right.... cause first of all i dont know anything about spring rates... so i wouldnt know what does what. Secondly, yes, a lot of roads suck ass over here so it can be a bumpy ride..... and thirdly, i am going to be using this as a daily driver which i wouldnt mind losing some comfort, but to a certain extent. So you think the OTS rate would do for me. Can the spring rates be adjusted later?? and the koni yellow are adjustable right.... i can adjust the height as well as the stiffness?
hey schmoo quick question which is better the p72, p28 or p30? for future refference...
The P72 has knock sensor and IAB support, the P30 has knock support, and the P28 has neither. As long as you don't care about a knock sensor or IAB's, the P28 will run the car the same way a P72 or P30 will. You can also disable the knock sensor and IAB support through any Honda ROM editor.
