Motor Build Question [Split from ITR Side Skirt Thread]
appreciate the comment, guess your new, i have done a lot to it already, port job, new valves,retainers and springs with Skunk2 cams, looking into cam gears,pulleys,bigger injectors and then off to re-tune the car... also welcome to HAN.
stage2, yes im going to get pistons/rods,cause of my turbo plans for next Spring/Summer... im buying the injectors now so i have them for next summer. trying to gather all the pieces that arent included in the kit.also i still have my ITR cams, would they be good for 300+WHP, or should i get the turbo cams from skunk2.
ohh and why are the pulleys useless, why the heck did people ever make them then, dont they get you at least 5hp.
keep your ITR cams, those will be just fine, no point on wasting money on skunk2 turbo cams, but here is your problem, if u are doing stuff for turbo, u might as well go lower compression pistion's but with stage 2 cams u will actually lose power, so like i have said before u really need to do more research, and kinda of plan this better cause u are kinda stuck between the n/a and boost area, so decide what u want and then get your parts accordlingly..
no no, fuck im confusing you am i, lets see if i can be a lil more clear , i will take out the Skunk2 cams and any other shit that wont go with the turbo, uncle will help me out whit this part, and sell them to my buddy, will buy the lower comp. pistons along with the injectors and upgraded fuel pump, then by the time summer comes i should have $3000 or more saved up to buy the turbo kit, do you get it now..
p.s dam are u serious about that man, then wat, is my ITR pulley better than any other aftermarket one..
In the future, when your questions don't fit in with orginal topic of discussion, please start a new thread.
Thanks.
All I ask is that people either start a new thread or contact the member via Private Messaging....
DaGip -- Whats your HP goal? If you've made it this far, how much boost do you want to run?
Depending on your goals, you might want to get your block sleeved. With the amount of downtime your going to need for all this, you might look for a b18 - or even a b20 block somewhere and start building that as you have the money. I went with Eagle H beam rods, Wesico Pistons (9.5:1 CR), & a stock GSR head with ITR cams & cam gears. With proper tunning this should be good for just under 300 WHP.
And for the record, i remember your first post stating what all you had done.
A few more "noob" suggestions...
-- Forget the camshafts for now, you have alot more important things to worry about going F.I.
-- Do lots of research, and forget the "kit" your planning on. Peice together your own setup, you'll save alot of $$ in the long run.
