Motor Build Question [Split from ITR Side Skirt Thread]
Old 09-06-2006 | 11:17 AM
  #31
2001TEGGSR's Avatar
2001TEGGSR
your on the right track. If you want to be completely safe you could always look at a dart block. For around $1800 you get a virtually bulletproof bottom end. This would be an excellent substitute to sleeving. You could get an aftermarket block griddle, Golden Eagle makes one.
Old 09-06-2006 | 11:57 AM
  #32
Snoopy's Avatar
Snoopy
been there done that
dart blocks need some machining to get them ready. i've heard of people getting their dart blocks and there still being tons of metal shavings inside. easier and cheaper to just sleeve your current block.
Old 09-06-2006 | 01:08 PM
  #33
2001TEGGSR's Avatar
2001TEGGSR
Oh really? h: I was unaware of this, as I just started pondering the possibility of using a dart block. This caught my eye "The massive block casting also provides an extremely rigid housing for the crankshaft. Stock and sleeved Honda blocks provide good crank support at moderate power levels, however, they were never designed for operation in the extreme HP and RPM ranges enthusiasts are pushing today. As a result, the (excellent) Honda crankshafts tend to support the flexing block leading to higher frictional losses and accelerated bearing wear. The Dart block presents the optimal situation, where the block supports the crank, providing the best possible foundation for performance and durability." Taken from Edyn's website. A machinist who is starting to recomend dart blocks over his own proven sleeving techniques.
BTW, I'm not disagreeing with your statement, just showing you something I read. What type of machining still needs to be done prior to use?
Old 09-06-2006 | 01:21 PM
  #34
Snoopy's Avatar
Snoopy
from reading a few threads on h-t about people with their blocks, it looks like you'll need to have it decked, bored and honed, align honed, at the least.
remember that it is completely bare. the only thing it comes with are the main caps and freeze plugs. in all seriousness, unless it's for a dedicated track car, just sleeve your stock block.
Old 09-06-2006 | 01:50 PM
  #35
DaGip's Avatar
DaGip
4N2Ner
yeah sleeving i already agreed to, first of all im only trying to achive 300-350HP, so i dont think i would need an dart block, also the $1800 is a lil too much for my budget, im sure with right internals that my motor should hold up 300WHP with no problems.
Old 09-06-2006 | 02:17 PM
  #36
Provocateur's Avatar
Provocateur
On permanent hiatus
Sleeving is so incredibly overkill on a setup only making 300-350 whp. But hey, if you want to waste money on it, be my guest. Funny how you want to sleeve it, but cheese out on the most important part of the turbo setup.
You are definitely not even close to being ready to pursue a project this large; you are in waaaay over your head.
Old 09-06-2006 | 03:05 PM
  #37
DaGip's Avatar
DaGip
4N2Ner
than what do you suggest. since you know a lot about turbos and stuff.
Old 09-06-2006 | 03:07 PM
  #38
Provocateur
On permanent hiatus
Forged pistons and rods are all you really need for that kind of power. Ditch the VAFC, find a tuner, and get whatever they feel comfortable tuning.
Old 09-06-2006 | 03:11 PM
  #39
Snoopy's Avatar
Snoopy
if you do want to sleeve it might as well overbore it too
Old 09-06-2006 | 03:15 PM
  #40
DaGip's Avatar
DaGip
4N2Ner
Schmoo have you not read my other posts, pistons and Rods are going in for sure, i just wanted to know what other safety precautions i could take, also im gonna go with the Hondata, GSSR already explained to me why not to use the VAFC, im just a bit curious to know what other small things you guys put into your engine to protect it from overheating,Blowing,not geeting enough spark etc.... its better to do it correct the first time, thats what im trying to do, and please i appreciate any help.
