Suspension Help
Old 08-29-2006 | 01:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by gsr2k
Will the ride height change?
That is dependent on the spring, not the shock.
Old 08-29-2006 | 10:24 PM
DaGip's Avatar
DaGip
4N2Ner
ok guess im fucked, ride hight seems lower then usuall, and when it comes to comfort, well its gone, its hard to explain how it feels when im driving. also the front right wheel is kind of slanted into the fender, would say like 2" more then the left side, could it be fucked.
Old 08-30-2006 | 04:20 AM
gsr2k's Avatar
gsr2k
Yeah, I know...I just wasn't sure if a blown shock would sieze or not expand all of the way and leave the spring somewhat compressed. My left rear sits slightly lower than the right side, which is why I was asking. The suspension is stock.
Old 08-30-2006 | 01:17 PM
Provocateur
On permanent hiatus
Could be. Check your suspension components, especially the shocks, springs, and perches. Make sure the perches are all tightened. Sounds like you have a serious problem, though.
Old 08-30-2006 | 03:49 PM
DaGip's Avatar
DaGip
4N2Ner
shit will find out this friday when i go get my o2 sensor replaced, still have my tokico set in the garage, would be a bitch if they are fucked up, they dont even have 2000miles on them...
Old 09-06-2006 | 06:07 AM
TruE320Ridah14's Avatar
TruE320Ridah14
So if I run 375f , 300r will this be a good street set up so I am not bouncing all over the place similar to cutting coils?
Old 09-08-2006 | 06:17 AM
TruE320Ridah14
bump for help see post above.
Old 09-08-2006 | 10:00 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
With the right shock -- like the Koni Yellows for example -- 375/300 will work fine. You must have a stiff enough shock to dampen the spring, so if you don't run them on full soft, you won't get that bouncy ride quality.
if you're going to spend most of your time on the street, you could come down to 300/250 as long as you don't lower the car so drastically that you run out of suspension travel.
Also, do not cut or torch your springs... ever.
