what ecu should i get?
Old 08-23-2006 | 06:09 PM
gsrvtec16's Avatar
gsrvtec16
Default what ecu should i get?
i have a 94RS witha 98 gsr swap witha jackson supercharger i just bought the car of some kid and the ecu was fried he had a p72 obd1 with skunk 2 chip but he thinks it got messed up cuz it was for all motor so now i biscally i need another ecu that obd1 people say to get the p72 stock but some also said get the p28 chipped so i dunno wut is best to get for the supercharger? any info would help thanks?
Old 08-23-2006 | 06:16 PM
Snoopy's Avatar
Snoopy
been there done that
get whichever is cheaper, chip it, get hondata, tune it.
Old 08-24-2006 | 06:34 PM
jrw1818's Avatar
jrw1818
can you tell me exactly what hondata does.. an is it a chip or does a computer at a shop hook up to it an change things?
Old 08-24-2006 | 06:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
www.hondata.com
Old 08-25-2006 | 09:02 AM
200cs's Avatar
200cs
p72 has knock sensor capability, p28 does not. I would get p72 if possible.
Old 08-25-2006 | 10:40 AM
Provocateur
On permanent hiatus
The P30 does as well.
Old 08-26-2006 | 02:00 PM
jrw1818's Avatar
jrw1818
i was curious how a p28 would be faster if it was chipped. wouldnt a p72 be better to chip for a gsr??
does anyone know how much hondata cost to get?? an how its installed??
what is a knock sensor anyways??
Old 08-26-2006 | 02:47 PM
Snoopy's Avatar
Snoopy
if you still have the stock dual stage intake manifold of the gsr use the p72 as it can control them. if you have a single stage manifold you can use either p28, p30, or p72. if you use the p28 you can disable the knock sensor, which is used to detect detonation and will retard timing.
www.hondata.com
Old 09-05-2006 | 07:23 AM
96GsR06's Avatar
96GsR06
While I'm reading this topic I thought I'd ask:
If I Had a gsr, and decided to get a type R ecu...would it require any adapter harness, and if not, does it matter if its a JDM ecu or do I absolutely need a USDM ecu?
Old 09-05-2006 | 09:35 AM
Snoopy's Avatar
Snoopy
if you have a single stage manifold on your gsr there are better options than an itr ecu. the itr ecu has vtec set too high for stock gsr cams. as long as the ecu is the same obd as the engine, it should plug right up.
