b18c1 is obd1 or 2
The vin number is one way you can tell, I don't know if you found a vin plate anywhere on the motor. What does the distributor look like? One plug/Two plugs, square plugs/circular plug.
Originally Posted by pascal
how can i tel just from the motor?
If the motor is pulled out you can determine by the following factors, as long as it has not been converted:
What is the serial number directly under the engine code?
What year does it say on the front of the head, next to the P-72 stamp ?
Originally Posted by jesusublime99
By default, a 94-95 GSR motor will be OBD1 and 96-01 will be variants of OBD2
