How to Rid yourself of spongy brakes?
If any of you remember my preivious posts I got into an accident. I have gotten it down to the point that if my brakes were spongey the accident would probably have never happened. I got my car back from the shop that day with new motor mounts installed and I had to have some wheel lugs replaced. After I drove it off the lot I noticed the brakes were spongier than shit. It was pretty annoying. I'm going to get my car back in a few days.....how can I get them back to normal? I'm going to kill someone(possibly literally) if this happens again in the near future(not really literally).
Nic
-ciao
Nic
-ciao
Replace all the fluid in the lines. Use new FACTORY SPEC fluid. Replace all shoes. Sounds like you could have a torn brake line or some issue that wouldn't allow you to get correct pressure. Does the car stop like normal even with the spongy brake-feel?
i highly doubt you have a torn brake line, but it certainly sounds like there's air in the system. for starters, swap out all of the brake fluid and bleed the lines.
Nic
-ciao
Originally Posted by asheylarry
rotors and pads could be glazed and the pads cant grab. but most likely air.
