help changing motor from 88RS to 87 LS
need advice. i am putting a 1.6L dohc from an '88 integra RS into a '87 integra LS. everything went great until i got to the distributor hookup. the cars have different types of distributors and the wiring harness connections differ. this seems to be the final connection needed. has anyone out there tryed this and succeeded. need help! i know someone out there has done this.
86-87 Integras run a vacuum advance distributor, 88-89 use an electronic advance. They are not interchangable. If you are using the old harness and computer, use the old vacuum advance distributor.
and which cpu should i use? thanks for responding.
Originally Posted by helpinalva
the '88 electronic advance distributor does not fit onto the '87 vacuum advance mount.
If you want to use that engine, I guess you'll have to convert to an '88-89 electrical system.
how about the details on that helpinalva
I ran into the same problem.put an 88 motor into an 87 car,you can change the top cam cap on the distributor side with the 87 model and you can bolt on the 87 distrib with one bolt.also just put the crank sensor in the other hole and it will bolt up with one bolt as well.I also put the 87 intake manifold on so i could use the 87 engine wiring harness
