Type R shift boot
Old 05-10-2006 | 07:47 AM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
Default Type R shift boot
Just got the new boot and was wondering if anyone has any pics on how to install the boot or if anyone can explain it?
Old 05-10-2006 | 09:46 AM
sherwood's Avatar
sherwood
I missed Sean
i'd imgine that you wold have to first unscrew the shifter knob then remove the center console, then the mid console peice by removing the screws on the side and such, pulling it off the shifter and the taking the boot out, placing the new one in and putting it all back together
Old 05-10-2006 | 10:03 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yep. Just pull out the console and unscrew the boot from underneath.
Old 05-10-2006 | 12:21 PM
JLO's Avatar
JLO
SOlid so its a super simple task
thanks guys
Old 05-10-2006 | 06:19 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
1. Undo the shift knob.
2. From the back of the center console undo the 2 retaining screws on both sides.
3. Pop that cover off where the ebrake handle drops and take out those screws.
4. By now you should be able to lift the whole backside of the console out.
5. Remove the retaining screws on front left and right side of the front of the center console and pop it off.
6. Without undoing the cigarette lighter you should be able to tip that part high enough to undo the 4 screws holding the bag to the retaining frame that screws to the underside of the console.
7. Once that is out sit back, take a look at it and remember how the bag in woven in and out of the metal prongs.
8. Take the old bag out, put the new bag in and retrace your steps to re-install everything.
Old 05-10-2006 | 06:33 PM
Joe's Avatar
Joe
I want a type r shift knob :hs:
Old 05-11-2006 | 06:12 AM
JLO's Avatar
JLO
Ebay my friend Ebay and thanks for switching you pic joe
