Bent Valve. Pics of the carnage!
Old 05-08-2006 | 03:59 PM
sherwood's Avatar
sherwood
I missed Sean
exactly what was the problem with your stock gs-r springs?
Old 05-08-2006 | 04:28 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Dont forget to put the head gasket on properly.
Hope it all comes back together without any problems.
Old 05-08-2006 | 05:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I was replacing the valve seals, so I figured I might as well put in some ITR valve springs to go with my CTR cams and rev a little higher. If I can make power that high, why not?
Oh you know I triple checked before I placed that head back on the block.
I will be ripping it apart again tonight to see if I can find that improperly installed valve spring.
Old 05-08-2006 | 08:41 PM
quikflip27's Avatar
quikflip27
Schmoo, jw, how/what did you use to remove your valve seals? and if it was a specialty tool, where did you get it? im breaking down my old b18b right now and those seals are all that are left. ive heard people using pliers on them but the metal the seals are made of bend really easy, any help appreciated
quikflip
Old 05-08-2006 | 09:59 PM
Provocateur
On permanent hiatus
quikflip
I just used a set of pliers. Make sure they are set to open as far as they can so they can get a better grip on them. Pull on the seals as hard as you can while wiggling them a little bit and the rubber holding them to the guide will give. You pretty much have to pull until you are sweating and your whole body starts shaking.
After 148k miles on mine, they were a little stubborn, so you just have to keep pulling and wiggling until they come off.
Old 05-08-2006 | 10:01 PM
Provocateur
On permanent hiatus
Update:
I got the GSR springs back in there and the ticking is gone. I went through all the ITR springs beforehand to see if I messed up installing them and they were all good, so I can't really figure out why they were making so much noise. At this point, I don't really care since I am so pissed that I had to go through all that effort and in the end, just had to put the stock ones back in.
The whole weekend was just a huge mindfuck, so hopefully after a valve adjustment, the valvetrain will sound like it did before I decided to mess it all up.
Old 05-08-2006 | 10:41 PM
1turbodc2's Avatar
1turbodc2
got boost?
Originally Posted by Däs Schmoo
Update:
good thank god now leave it be!!!
Old 05-09-2006 | 02:36 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Update:
I hate when that happens. It seems like just about everytime I decide to go out and tackle a project or issue with my car, I just end up making things worse or accomplishing nothing. :sad:
Old 05-09-2006 | 11:54 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Update:
Been there dude. The first time I ever dropped cams in my 89 Integra w/the zc engine it was all over the place idle wise, was burning real rich and going through gas like a son of a bitch. It was quick, but I could not drive it like that. Thought I was doing something good by adding power, but it the end just ended up putting the stock cams back in. So what was the point is what your feeling right now. You'll get over it.
Old 05-09-2006 | 07:09 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Shitty mang,
At least you have the brains and the tools to get the job done though, man.
Best of luck getting her running again!
