Bent Valve. Pics of the carnage!
Old 05-08-2006 | 08:22 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by centerforce99
I would not worry too much about the valve springs and the noise. I am pretty confident that you did everything right so it cannot be messed up. The noice your hearing is most likely due to 1 of 3 things. They are like way newer than what you had in there so they may need to break in a little. Or two, Type R springs are wound just a bit in difference for the higher lift cams they support and this is the noise that it yields. Or 3 you may be hearing the valves not the springs, in case they were not adjuested correctly, but you've done that a million times over so I doubt it is 3, but just in case...
They are wrong. I started a thread about that on honda-tech and there shouldn't be a noticable difference in sound. The guy I bought them from claimed they only had 30k kilometers on them and they looked like they did compared to my old valvesprings.
I am going to be ripping it apart again today after work and putting my old valvesprings in since I know those worked.
Old 05-08-2006 | 09:00 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
I was about to say... a noise valvespring sounds like it might be binding at full lift. Talk about your ticking timebombs. :noes:
Old 05-08-2006 | 10:35 AM
Provocateur
On permanent hiatus
Yeah, I am thinking I put one of the exhaust springs on upside down, so the tightly coiled part that is supposed to be toward the head is against the retainer. That would add extra mass causing the noise.
Old 05-08-2006 | 11:48 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Is it possible, now just brain storming here. Maybe, just maybe...the ITR valve springs and CTR cams won't work together w/o the exception of this noise??? Did you consider CTR valve springs? Would that have even fit? Not sure, just saying...
Old 05-08-2006 | 12:03 PM
Provocateur
On permanent hiatus
All vtec springs are interchangeable. I don't think it is a problem with the springs, but rather my installation. I am going to be ripping it apart tonight anyway. If I can't find the spring that is upside down, I am going to be pulling them all out and putting the stock ones back in. If the noise is still there after that, I am going to be looking at a new head since something is jacked up beyond what I can fix with it on the car.
Old 05-08-2006 | 12:04 PM
asheylarry's Avatar
asheylarry
maybe i missed it somewhere in the thread, but what the hell happend? was your timing off? or was your valve lash waaaaaaaaaaaaaaaay too tight? what happend?
Old 05-08-2006 | 12:35 PM
Provocateur
On permanent hiatus
I am still trying to determine why it bent. I am thinking that the spring bound and wouldn't let the valve back up and it contacted the piston upon start up. The timing was good too, so I have a feeling it was a valvetrain malfunction.
Old 05-08-2006 | 01:49 PM
1turbodc2's Avatar
1turbodc2
got boost?
dude i am so sorry that freakin sucks big time!!! seeing it is like holly Sh*T
Old 05-08-2006 | 01:58 PM
asheylarry's Avatar
asheylarry
thats shitty bro.. were the springs new or used?
Old 05-08-2006 | 03:30 PM
Provocateur
On permanent hiatus
They were used. The seller said they had 30k km on them and they looked like they did. I think it was an installation error, not a spring problem.
