Tuning Help
Tuning Help
I need some help with changing my cooling system, transmission fluid, brake and clutch fluid, power steering fluid and spark plugs. I am new at tuning my car, I have a 97 gsr 2dr. I have the manual but I wanted to know if what the manual says is all I need to do and what type of spark plug to get as well as the different fluids. I would really appreciate it if I could get some pointers.
It is all pretty straight forward. In terms of fluid, any DOT3 or DOT4 brake fluid will be fine for the clutch, any autoparts coolant will be fine for the radiator flush, PS and MTF should be Genuine Honda fluid.
The proper spark plug should be stated on the underside of your hood. NGK platinum in heat range 6 should be what you are looking for.
