intake and exhaust cam
Old 05-04-2006 | 04:54 AM
NwAmH's Avatar
NwAmH
hatch that gets snatch
Default intake and exhaust cam
Have a set of Pr3 cams going into a P72 head. I cannot tell the difference between the intake cam and the exhaust cam. Can someone help me out with this?
Old 05-04-2006 | 11:39 AM
NwAmH's Avatar
NwAmH
No one have an idea?
Old 05-04-2006 | 11:59 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Intake has a groove for the distributor.
If you are trying to identify the cam by the gears, you can't do that. All B series cam gears have PR3 on them.
Old 05-04-2006 | 12:29 PM
NwAmH's Avatar
NwAmH
www.jdmuniverse.com/forums/showthread.php?t=43150
this link i found has the works on it to show the difference from ITR, CTR and GSR cams, intake and exhaust
Old 05-04-2006 | 12:30 PM
NwAmH's Avatar
NwAmH
btw the cams i have are ITR's with the single band around the end
Old 05-05-2006 | 04:55 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
*cough* Staying on the topic of camshafts...:a: *cough*
Old 05-10-2006 | 09:21 AM
NwAmH's Avatar
NwAmH
Default Remove these valvesprings!!!!!!!!!!1
JDM products are getting expensive tho like type r USED Rearco "however u spell it" sell on JDMSh!t for like $1k and they USED!!! BTW, any suggestion for removing vtec valve springs, i know C-clamp style valvespring compressor work but with a special extension i can't find
Old 05-10-2006 | 10:05 AM
Provocateur
On permanent hiatus
To do it with the head on the car, you need the snap on tool or equivalent and an air compressor. The tool is just two uprights, a bar that goes through them, and a handle that attaches to the bar that will give you leverage to compress the springs.
Old 05-10-2006 | 11:39 AM
NwAmH's Avatar
NwAmH
Hey my head is off and as for Snap ON tool....the company makes a special valve spring compressor?
