Just got my RSR exhaust, but my GSR won't turn on anymore...
Old 05-01-2006 | 07:23 PM
jesusublime99's Avatar
jesusublime99
Default Just got my RSR exhaust, but my GSR won't turn on anymore...
UPS guy just delivered my new RSR ExMag exhaust today and I can't wait 'till I put it on! Also I just installed my new Greddy header on Saturday night- my first 2 upgrades after my extensive tune-up; but when I tried to turn on my car on Sunday, it wouldn't start anymore. I checked my battery's voltage and it was good. I think it may be my starter; it doesn't even crank. It has never hesitated when being started.
I have 2 questions, any and all help is truly appreciated:
How can I test the starter?
What else could be the cause?
Old 05-01-2006 | 07:32 PM
sherwood's Avatar
sherwood
I missed Sean
what exactly was this extensive tune up
Old 05-01-2006 | 07:45 PM
jesusublime99
Just to clear things up, this tune-up was done about 3 months ago, right after i bought my car. All parts and fluids OEM Honda, unless otherwise noted:
NGK Iridium spark plugs
NGK wires
Fuel filter
Dist. cap & rotor
PCV valve
K&N drop in filter
Mobil 1 5w30 with Honda S2000 oil filter
Brake fluid drain and refill
Tranny fluid drain and refill
Also, valve adjustment was done.
Old 05-02-2006 | 05:04 AM
Joe's Avatar
Joe
My starter is pretty much shit right now, ill go to turn on my car and the car goes : click, click , click , click siiiiigh click , click vrooooooum aaah finnaly.
Old 05-02-2006 | 05:17 AM
reno96teg's Avatar
jesusublime99, given that the car failed to start immediately after you installed the header, i would check all wires and connections in the area. you could possible have knocked something loose or forgot to plug something back in.. go over everything.
starters usually don't fail from one day to the next.
Old 05-02-2006 | 06:02 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
NGK wires
Fuel filter
Dist. cap & rotor
PCV valve
K&N drop in filter
I'll bet you put the wires on the distributor in the wrong firing order. I'd check that first.
Old 05-02-2006 | 06:40 AM
gsrtommy's Avatar
gsrtommy
if u want to see if its the start tap the cylinode with a wrench or something metal and as your doin it have somone try to start it. If it turns your starter is shot
Old 05-02-2006 | 07:10 AM
g290ls's Avatar
g290ls
they call me tater salad
im willing to bet that its not the right firing order, check that first and hen try it again
Old 05-02-2006 | 07:23 AM
krweby's Avatar
krweby
x2
The wrong firing order will not keep the starter from engaging.
Old 05-02-2006 | 07:56 AM
westcoaststyle
If you turn the key and you hear the motor turning and trying to start then the starter is fine. You guys have some crazy ways of diagnosing problems. :noes:
