premium unleaded in an acura integra gs-r
Old 04-27-2006 | 02:17 PM
  #31
Nors's Avatar
Nors
倍力恋
pinging and knocking... and since there is a knock sensor it will retard your timing until it stops pinging
Old 04-27-2006 | 02:27 PM
  #32
Originally Posted by BADST GS-R
Spool... think outside the of box for a moment. Not spools as in "a turbo spooling up". A spool is a type of posi differential on a rear wheel drive car. Both wheels will turn at the same rate even when turning causing some un-godly noises.
Fart cans are lame.
Big wings are even worse.
I misunderstood... ive only heard posi used in domestics :chuckles: sorry... and i have no clue why I highlighted the last 3 when i meant to do the ones prior to h: there :run:
Old 04-27-2006 | 03:24 PM
  #33
rugsr's Avatar
rugsr
How do my taillights look
Low Octane = More Power Cuz It Burns Faster?
Old 04-27-2006 | 04:56 PM
  #34
Nors's Avatar
Nors
倍力恋
sort of, it all depends on compression, higher compression causes more heat which needs more resistance to combustion, which is octane.
i believe higher octane gas has lower BTUs then lower octanes.
Old 04-27-2006 | 05:17 PM
  #35
higher octance is less prone to detonation... basically burns slower...
Old 04-27-2006 | 06:04 PM
  #36
rugsr's Avatar
rugsr
Ah Cool. Learn Something New Everyday
Old 04-27-2006 | 06:31 PM
  #37
BADST GS-R's Avatar
BADST GS-R
Originally Posted by sherwood
uh... thats called an open differential.
there is nothing "posi" about it.
You couldn't be more wrong. An open differential is one in which the power is transferred to one tire... not two like a limited slip, or a posi, or a spool, or a locker. Looks like someone needs to watch "My Cousin Vinny" to become educated.
Old 04-27-2006 | 06:52 PM
  #38
BADST GS-R's Avatar
BADST GS-R
I wouldn't necessarily say that. You will never achieve more power using 87 octane in an engine that requires 93 octane simply because the lower octane gas will cause the engine to knock (detonation), the knock sensor will pull timing, and thereby taking away power. In a car without a knock sensor such a race car with an engine that requires high octane, is built to handle detonation if it were to occur, but is tuned properly in the first place. Even some new cars today don't have knock sensors such as some Fords (the old supercharged T-Bird, the Lightnings, and even the '03-'04 Cobras don't really have an effective knock sensor like GM) a ), but are tuned properly. What would happen if you tired to cheap out by putting 87 octane in a Lightning? Kaboom!
Old 04-29-2006 | 09:49 PM
  #39
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
As Long as I know that I should run premium on my GSR engine, its ALL good.
Old 04-30-2006 | 12:44 AM
  #40
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
haha yeah that turned into a huge post... the answer for you is "yes" don't bother with anything else
