H22A or B18c Type R....Need help guyz!
#33
Originally Posted by bbasso
It's B18C5 for 96-01 ITRs.
Wow... You've been in a closet for a tid bit haven't you?
B18C5 97+ is for USDM Spec ITRs
B18C 96+ JDM ITRS
B18C3 is I believe Australian...
B18C4 is I believe UK
etc....
Not too sure bout the last two, but I know for certain everything else is right. The JDM ITR Engine Code only had B18C stamped on them. C5s were USDM
#34
only non JDM engines had the number stamped on them. the only way to tell the difference is the headstamp, and for reference to wether we are talking about a b18cR (type-r) or a b18c (SiR-G) motor is to simplify it.
to be correct it would be a P72-B18C for the SiR-G or PR3-B18C for type r's, but no one knows what that is talking about at all.
#35
B18C 96+ JDM ITRS
etc....
B18C 96+ JDM ITRS
etc....
but i was referring to US ITRs. and some of the 97's were made in 96, that is why
I listed 96-01.
yeah I live in a closet...
#36
h22 in a 92 civic...
I have a 92 Civic LX with a h22a1 motor in it, the power is impressive, and in every gear when I hit vtech it gives a great boost. If you check the forums u can see that there are mount kits available to mount the A/c in a civic after you have done the swap. Just to let u know... never encountered anything quite as fun as a huge engine in a little car, if you lived in oregon I would let you drive it if u wanted.
Hope it helps...
Hope it helps...
