cams for gsr
cams for gsr
im thinking of gettin cams for my 98 gsr im a little confused about what to get, some of my buddy's say to go with stage 2 cams and put a chiped obd1 comp in. im not sure what type i should get, i use this car everyday and i just want like 10 - 20 hp gains.which company should i go with toda, skunk 2, or cower and should i go with stage 1 or 2. also im gettin springs retainers and gears. any help would be great.
Originally Posted by centerforce99
Throw in a CTR intake cam and call it a day. After adjusting the valves ofcourse...you'll get about 10-12hp, be able to maintain yout stock rev limiter, valves, springs and retainers.
Stage 2 cams are good, but you won't see the best gains from them without a better flowing manifold, higher compression, and some method of tuning. They will give you the gains you want with stock compression, but to have them idle and function correctly, they will need some way to modify the stock fuel maps and vtec engagement point.
well i want to rev it out higher thats what the chiped obd1 comp is for so maybe ill just go with the toda spec A2 (stage 1) cams, vavle springs and gears, that alone should give a good 15+ hps. what do u think
Originally Posted by Däs Schmoo
I highly doubt it is that much, especially if you keep the stock intake manifold. I probably got more than 10-12 hp out of the CTR cam swap, but I am also boosted and have proper tuning and a better flowing manifold.
Ok, so it was a crappy guestamation. What, 8hp? that was my original thought, but I wanted to give the CTR's more credit.
