engine swap (TL or CL)
Old 04-13-2006 | 01:19 AM
dorkunderfire's Avatar
dorkunderfire
Default engine swap (TL or CL)
i'm looking for a good engine swap to go into my '97 integra. is it possible to swap in the motor from an acura CL or TL? also, since most of the engines are automatic, what's the best easily-found transmission i could use with those engines in case the best deal i can find happens to be with an automatic tranny? thanks for your help.
- Sean
Old 04-13-2006 | 03:35 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Ive never heard of that being done???
If youve got an automatic LS, why not put in a b18c and convert to 5 speed??
Old 04-13-2006 | 03:57 AM
Exadar's Avatar
Exadar
Be Quiet and Drive
To the best of my knowledge that would be more or less impossible without doing HUGE amounts of modification to the engine bay and probably the frame. The teg is designed for a 4 cylinder engine, unless you get the 2.2CL engine, they're gonna be 6 clyinder engines and again, way too big.
Out of curiosity, what is wrong with the engine in your car now? And is it a b18b or b18c1? (I'm assuming b18b)
Old 04-13-2006 | 08:01 AM
ISP James's Avatar
ISP James
DAMIMRED
a tl or cl swap would result in extreme damages to your financial comfort.
in the end not worth the money and down time.
if you want the biggest easy(easier than tl/cl), go with an H22. want easy, go with any b series. or just spend your money on a turbo for your b18.
Old 04-13-2006 | 09:02 AM
jdmeg6hatchy
i
where did you ever get the thought of putting a TL or CL in the integra?
Old 04-13-2006 | 11:27 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
- Sean
A V6 swap for your DC Integra is nigh-on impossible. You're looking at frame and firewall modifications, completely custom wiring and a set of custom mounts. You could esily spend $10k on such a swap and make about the same amount of power as a turbocharged LS or GSR.
The J-series V6s are much larger than the B-series Inline-4s. When combined with larger transmission, I doubt you'll have anywhere near enough width in the engine bay to mount the drivetrain.
What model Integra do you own?
A GSR? Or an RS/ LS / GS? 4-door or 2-door?
Where do you live? In California, your options are somewhat limited.
The most realistic option for an Integra of your model year is a bolt-on turbocharger. GReddy makes a CARB-legal kit for the DC2 & DC4 coupes, which can be installed on the DB7 & DB8 sedans as well.
Lastly, welcome to HAN.
Old 04-13-2006 | 02:54 PM
dorkunderfire
i live in vancouver, and own a 5-speed integra "anniversary edition". pretty much the GS. 140hp.
i got the idea because i was looking at the type R engine for a swap, but i wanted an engine with more torque then the type R, but still around 200hp...ergo, the TL and CL engines..
there's absolutely nothing wrong with my engine now, and i wouldn't do anything unless i was completely sure of the change. however, i'm wanting more power out of my little integra..more pull while accelerating.
thanks for the quick replies..and since the TL and CL are out of the question, what's my best move in this situation?
Old 04-13-2006 | 05:32 PM
TheOtherDave™
Apathy Kills
Turbocharge your stock B18B1 motor, upgrading the clutch simultaneously. I don't now Canadian emissions law, but one of the most complete turbo-kits on the market for a basic daily-driver application is the GReddy turbo kit I spoke of earlier (see the last paragraph of my first post).
The MSRP on the GReddy kit is about US$3200, it will add 50+hp and 60+ lb/ft of torque on 91 octane petrol. If you get 93 or 95 up in your area, there's no reason why you could make about 210hp at the wheels with a bit of dyno time and a professional tune.
Old 04-13-2006 | 05:41 PM
AcuraFanatic's Avatar
AcuraFanatic
That would be THE biggest waste of money, ever.
Might as well take 100 $100 bills and flush them down the toilet.
Old 04-14-2006 | 02:21 AM
dorkunderfire
now it's funny you say that. i tried just that, but didn't notice any power increase to my stock integra engine.
