Installing Turbonetics Turbo
Originally Posted by IntegraGSR12
Well I just found 2 bung plugs in my hardware. I wonder if I plug the whole in the downpipe since like you said it points kinda downward , and leave the o2 in the cat. The o2 is at the beginning of the cat that is the only o2 I see should there be another at the rear of the cat? I dont see one there??? They included two plugs with this kit where would they go you think?
sounds good but it is still confusing me as to why in the directions it says to remove the o2 from the exhuast manifold. It is made for the 94-98 gsr do any of these years have a o2 in the ex manifold???? If not why would they put that in there but it doesnt ever say to hook the o2 into the downpipe nor does it say to plug it. It just kinda assumes the installer knows I got some other contacts that I can get ahold of tommorow but I bet what you said will be correct
and if I only have one o2 sensor wouldnt the obd2 pic that up and throw a check engine light? My car does have the obd2 since its a 96 right?
I did find the posterior o2 so that puts me at 2 o2 sensors. So I should be able to plug the downpipe with the bung here are the pics so you can verify. Also I am changing over to the obd1 for tuning perposes along with a hondata. Can I run both o2 sensors with the obd1 or would it be better to run it with just 1???/
Just plug the downpipe and you are good to go. :thumbup:
