Oil Lines$!$!$!$!$!
Old 02-16-2006 | 08:31 PM
rugsr's Avatar
rugsr
How do my taillights look
Default Oil Lines$!$!$!$!$!
Its now time to buy oil lines and on ebay the feed is 70 shipped and the drain is 90 shipped? BALLS thats a lot of cash. nice thing is it comes with the fittings and bolts and elbows but is it worth getting or should i try to piece some together
http://cgi.ebay.com/ebaymotors/T3-T4...QQcmdZViewItem
Old 02-16-2006 | 09:43 PM
FooD2000's Avatar
FooD2000
Still Water
i'm assuming this is for a turbo? That's pretty expensive. On homemadeturbo.com, there's a well known guy on there who sells oil line kits. Hes got a good rep there. That's my plan so check it out.
http://www.stealthmodeperformance.com/oil.shtml
Old 02-16-2006 | 10:01 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here is a good link for some oil lines. http://tunertoys.zoovy.com/category/oillines/
You have to measure your oil return flange spacing to order the correct kit.
Old 02-17-2006 | 08:37 AM
rugsr's Avatar
rugsr
i only see the drain flanges in these kits. i assume i gotta buy the inlet flange? how do u size from the center to the edge?
Old 02-17-2006 | 11:59 AM
Provocateur
On permanent hiatus
They are the full feed and return line kits. I would assume that you would have to measure from the center of one bolt hole to the other. Measure and see what yours is closest to and that will be the kit you need.
Old 02-17-2006 | 02:03 PM
carta79's Avatar
carta79
Life after death
Yeah those stealthmode oil lines look pretty solid. I like the price, I'm getting a set. I wonder if this kit would bolt up to a golden eagle 1/8npt oil block adapter.
Wouldn't the 50.8mm T3/T4 stealthmode lines work for him.
Old 02-17-2006 | 08:55 PM
rugsr's Avatar
rugsr
the turbo is the Precision SC-61 i believe. Still the kits are nice looking BUT i dont see an inlet flange!
Old 02-17-2006 | 09:09 PM
rugsr's Avatar
rugsr
same turbo i have here and im almost POSITIVE i need an inlet flange on her. unless theres a different way to hook it up using them stealth kits
THE TURBO
http://cgi.ebay.com/ebaymotors/Brand...QQcmdZViewItem
the inlet flange
http://cgi.ebay.com/ebaymotors/T3-T4...QQcmdZViewItem scroll down half way and youll see the flange
Old 02-18-2006 | 10:48 PM
rugsr's Avatar
rugsr
anyone seeing what im seeing here? or am i wrong
Old 02-19-2006 | 07:16 AM
5 Lug's Avatar
5 Lug
What's up rus, you need me to take a picture of anything? I'm going to anyway, haha, check your mail.
