B18c Engine Question
Old 01-24-2006 | 11:38 AM
1SLIKTEG's Avatar
1SLIKTEG
Default B18c Engine Question
Hello, Im New To This Site I Just Registered. I Have A 2000 Gs Integra With A B18c Swap And Ls Tranny. I Have A General Question, Im Not Sure If I Have The Sir B18c Or The Type R B18c, How Do You Tell? One Has 178 Hp And Other Has 200hp, Id Definately Like To Know. Thanks
Old 01-24-2006 | 11:41 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
look to the left of the exhaust manifold, should be a little plate attached to the engine, or an imprint, I can't remenber which that has the engine code..
b18c1 = GSR engines, b18c5 = Type-R engine (note: you'll see ppl say ITR a lot, that'd be a type-r, so you're less confused.)
there's the off chance that it's a japanese crated engine, which, if someone can correct me if i'm wrong, doesn't tell the difference between the 2 engines on the code... there may be a way I don't personally know of, or run it on a dyno and find out what's going on.
p.s. welcome to HAN :cheers:
Old 01-24-2006 | 12:23 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
if it has a ls tranny im gonna guess its a gsr motor. but ninj4r is pretty much right
Old 01-24-2006 | 12:40 PM
1SLIKTEG's Avatar
1SLIKTEG
I kept my original Tranny, Just Got The Engine, So Im Still Not Sure Whether It's A Type R Or Sir But I Guess The Only Way To Tell Is To Dyno It
Old 01-24-2006 | 01:11 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Hi, welcome to board.
Please turn off your CAPS LOCK.
Thank you.
Old 01-25-2006 | 04:34 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
check the head cast to see if it says p72. p72=gsr p73=type r. or the gsr intake manifold is a dead giveaway
Old 01-25-2006 | 04:42 PM
sherwood's Avatar
sherwood
I missed Sean
yeah, you check the cast, if it's
p72 it's a gsr
pr3 it's a type-r
Old 01-25-2006 | 05:00 PM
aboobybobpleez
yea pr3 excuse me
Old 01-26-2006 | 07:44 AM
1SLIKTEG's Avatar
1SLIKTEG
thanks guys ,its a gs-r then so that means 178hp or what?
Old 01-26-2006 | 07:47 AM
AcuraFanatic's Avatar
AcuraFanatic
USDM GS-R is 170HP.
