B18c Engine Question
Old 01-26-2006 | 07:58 AM
1SLIKTEG's Avatar
1SLIKTEG
But I Have A Jdm B18c Swap
Old 01-26-2006 | 10:14 AM
AcuraFanatic's Avatar
AcuraFanatic
Then 180HP
Old 01-27-2006 | 06:47 AM
1SLIKTEG's Avatar
1SLIKTEG
got my teg on the dyno last night, max was 145hp to the wheel with 109 lb torque, thats depressing, the guy there told me i needed bigger cams, any suggestions, crower, comp, oem type-r?
Old 01-27-2006 | 07:04 AM
sherwood's Avatar
sherwood
I missed Sean
gsr cams are nice.
145 hp to the wheels is about on for a usdm gsr... not sure about the jdm p72 tho
if you want more power find a turbokit, cams and everything will end up costing you more for the same ammount of poer or less and wont be as upgradeable.
Old 01-27-2006 | 07:56 AM
1SLIKTEG's Avatar
1SLIKTEG
couldnt i do bigger cams and a turbo. so your saying i should be getting more hp to the wheel out of my jdm b18c?
Old 01-27-2006 | 04:12 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
if you truely have a JDM b18c, yes, but not more than 10-15 more hp, it's basically negligable (sp?), larger cams will give too much overlap for the engine to run efficiently with the turbo. CTR cams would work great if you were to turbo, but generally something like cams rarely get touched on a turbo engine... just the way it is
