Baaaaaaaaaad Turbo Fitment!
Old 01-19-2006 | 06:20 AM
rugsr's Avatar
rugsr
How do my taillights look
u did....dont remember. why would i have problems. turbo 2 big, weird manifold?
Old 01-19-2006 | 06:59 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
You can get slim fans from all over the place. Summit is one place I'd look at. Another thing you could do for even more clearance is use a "pusher" fan and place it in front of the radiator.
Old 01-19-2006 | 07:00 AM
2legit2quit
You Big Dummy
Double post.
Old 01-19-2006 | 07:39 AM
rugsr's Avatar
rugsr
ya know i was just thinking that 2. is there a difference of a pusher fan and my regular fan? can i just take the reg fan and put it in front of the fan. if not.....what if i get 2 slims and put them in the motor bay, and 2 pushers and put it infront of the radiator, over dooing it or no? the cooler the better right?
Old 01-19-2006 | 07:56 AM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
The problem with putting the reg fan in front of the radiator is it will be pushing air in the wrong direction (pushing air towards the front of the car instead of the engine). Reversing the polarity may make the fans spin in the opposite direction to get that effect, but I wouldn't recommend it. The fan-blades are not shaped to efficiently push air in the other direction.
Go with some slim profile fans as mentioned by others. You should be able to find some that will work for you. If there is still not enough room for slim fans then find a way to move the radiator forward slightly.
Old 01-19-2006 | 08:08 AM
BLKGSR's Avatar
BLKGSR
Have an elbow welded togeather to clear the motor.
Old 01-19-2006 | 08:23 AM
rugsr's Avatar
rugsr
found these http://www.sportcompactonly.com/prod...tm_medium=shop
and one of these should be good for the car....or mabye a slim on the pass side and a slim pusher on the drivers?
BLKGSR.....an elbow for what?
Old 01-19-2006 | 09:57 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i think he was talking about putting an elbow on the manifold and going to the turbo...but that wouldn't make any sense whatsoever because then the turbo would be pushing the radiator area even more
Old 01-19-2006 | 01:21 PM
rugsr's Avatar
rugsr
R U Talking About Putting An Elbow On The Mani For The Wg And Routing It Elsewhere?
Old 01-19-2006 | 03:47 PM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
Thats a option as well, but have you notched teh block yet?
