I dont think 175 is anything to worry about. If one or two cylinders were quite lower than the rest, you'd have something to worry about...or if you were 140 or below. I still think the test should be redone with the car warmed up, and throttle plate open.
do a wet compression test and see if it is either ur rings or valves
unless all his rings/valves are wearing or having problems 100% equally it wouldn't be something like that... it seems like it's fine... not a super high cr, if it was something like your rings or valves... you would have numbers that were uneven if it was 175 + ~1 or 2 then it's alright
