Best 2nd Gen. Power Maker
Old 09-12-2002 | 03:51 PM
alnen's Avatar
alnen
I haven't found any deals that are better than that, bookshelf. Maybe it's just my area or something. What would be a good deal for $3500 in your area? Later.
Old 09-12-2002 | 03:55 PM
90'RS's Avatar
90'RS
If the compression test comes out good you don't really have to beef up the engine at all as long as you keep the boost at a reasonable PSI. As for cost it depends on if you going to do the work yourself? Try a search for compression test because I remember a discussion on that not to long ago.
Old 09-12-2002 | 05:15 PM
g2tegls's Avatar
g2tegls
MR, ftw
A compression tester costs about $30-40. It's just a hose with a dial at the end, like a tire pressure guage. You screw it into the spark plug hole and crank the engine. Here's a how-to: http://www.c-speedracing.com/howto/c.../comptest.html
Ben
Old 09-12-2002 | 05:24 PM
alnen's Avatar
alnen
Wow that site was very informative...Thanks!!! I am really excited about getting a turbo. This sucks because I don't even have the car yet If it costs $3k for the whole turbo setup, I will have it all done in about a year
Old 09-12-2002 | 05:33 PM
alnen's Avatar
alnen
Oh, another thing is emissions. Would I be ok? I have seen several turbos in my area. I live in GA. I don't really want a Greddy, I want a little more power than it gives.
Old 09-12-2002 | 08:12 PM
lttletimmy's Avatar
lttletimmy
Drag
Revhard is good but i don't think they make a kit for the G2. But make sure your motor is strong before you go turboing it. I would replace all the seals, bearings and rings while i was at it too. Good luck
Oh, and you should be alright on emissions unless you go crazy
Old 09-13-2002 | 12:12 AM
G2Integrity's Avatar
G2Integrity
Oh, and by the way, the RS/LS/GS all have the same exact chassis. So the RS is not "sturdier" than the other two. It is lighter, but not sturdier.
Old 09-13-2002 | 03:10 AM
pomansouth's Avatar
pomansouth
i beg to differ the rs is stronger because it has no sunroof and i would get a drag III or just build your own but you have to do some homework for that and youll save about a grand if you build your own and look in the right places
Old 09-14-2002 | 03:56 PM
Bookshelf's Avatar
Bookshelf
highrevmotorsports.com
Well, in my area you could get a gen2 with only 82K miles for $3,800, so figure it out for yourself what you could get for $3,500. I got mine last year with 98K miles for $3,100 and it was in very good condition except for some minor rust. Look for something with 90K for the $3,500 you got. The best way is to go to www.autotrader.com, that's how I found my car.
Old 09-14-2002 | 07:37 PM
alnen's Avatar
alnen
I've been to Autrader. $3500 usually will get you a '90-'93 w/ 150-200k miles. I don't know why they are so expensive here.
Quick Reply: Best 2nd Gen. Power Maker
