HElp please my 94 RS wont start!!!
Old 12-01-2005 | 11:08 PM
94integrars's Avatar
94integrars
so thas the problem with the starter? im not sure. i got this rs from my friend last week . i have been driving for a week. b4 it was like when i hit the ignition key, it starts clicking after a second. its not like when you turn ur key it will start right away. i had to wait for like one second then the car start clicking and it starts no problem. thanks guys
Old 12-02-2005 | 12:54 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i'd say get that starter checked out...definately a good idea
Old 12-02-2005 | 01:48 PM
VPUPPY's Avatar
VPUPPY
Try tapping the starter with a hammer lightly. It may free it up - just a shot in the dark though.
Old 12-02-2005 | 08:12 PM
94integrars
thanks alot guys
i did hammbered the starter. it didn't work haha thanks tho.. i'll get the starter and check it out next week. thank you..
is anybody lookin for Auto Decals aluminum emblems and Auto windshield banner. MSG me if you have any questions TRD, HKS, GREDDY,CUSCO,SIR,SPARCO,MUGEN,APEXI, KONI, TOP FUEL,STI, SPOON, EIBACH, 5ZIGEN pleae feel free to ask me questions. thanks
Aim: Pqualityautodecl
Old 12-02-2005 | 10:06 PM
Amirked's Avatar
Amirked
I had a similar problem this summer. Try turning the key with the clutch at different heights - there is a clutch neutral safety switch connected to the pedal and it may have a bad connection - it seemed to work for me. I would have to turn the key 3 or 4 times and adjust the clutch height in between - that seemed to help. However, I believe my starter was also dying (95 ls) since it would progressively get worse. I replaced the starter myself which turned out to be a nightmare. It would have only taken about 2 hours but the new starter I bought wouldn't bolt in right (the mounting hole was off just a hair). I returned it and got a new one .. same problem. I tried a different store - same problem. At this point I thought I was crazy but, I fixed the situation by taking the part of the starter that connects to the engine off of the old starter and put it on the new starter. I pretty much used parts from the old starter and new starter to make one that would fit and work. Hopefully you won't have the same problem.
Also, check the negative ground for corrosion. My bro's 91 accord has similar problems and I ended up ripping out the battery and alternator to get them tested. Turns out they were both good and the problem was a stupid $7 negative ground that took 5 minutes to get out.
Old 12-03-2005 | 09:53 AM
tegbooster's Avatar
tegbooster
haha i saw ur other post *amirked*...sounds sucky...i think you mighta had the wrong one .... but 3 times as long as ur ure u got the manual version i just wouldn't go back to ur normal auto parts place
Old 12-03-2005 | 01:15 PM
Amirked's Avatar
Amirked
yeah that was a nightmare - at least the original lasted 115,000 so I doubt i'll be facing the same situation any time soon. But come to think of it that isn't the only part that hasn't fit perfectly - the knobs on the rear brake pads stick out too far and so the pads get stuck in the caliper bracket and won't move back and forth 0- i had to grind those down with a grinding wheel. I think I learned my lesson with aftermarket parts . .it is too bad too because I get a discount at Napa. Next thing I replace will be dealer only.
Old 12-03-2005 | 04:20 PM
tegbooster's Avatar
tegbooster
yeah... i usually do that...or directly from another one...when im doing OEM parts.... are u sure your car wasn't hit pretty bad before you got a hold of it....weird that nothing fits
