Strange thing happend today
I went out side and found my car antenna sticking up. I check the fuse and the antenna wire behind the deck. Simply put I can't get the thing to go down anyone experence something like this? the car is 81K miles.
Originally Posted by Inacurals
My antenna is constantly erect. the ladies love it.
Mine used to be erect all the time, but I like it when it can go down when I don't need it. h:
Mine used to always be erect. We(My dad and I) have replaced it 3 times after trying countless things to try to fix it. Nothing worked. I can't even remember if it still works. Its just a pain when you turn on the radio or cd or anything it goes up, so I just unplugged the motor and said screw it. I still get great reception, without the annoying noise of the antenna going up and down.
When mine started to go I wired in a switch on the center console to disable the antenna. I listen to CDs mostly and only use the radio like once a month so I just keep it turned off most of the time. It saves a lot of wear and tear on the motor assembly and it also looks better since you don't always have this freakishly large antenna always sticking up. I would recomend you do this if you replace the your antenna.
