Valve Help!!!
Old 11-20-2005 | 01:58 PM
GotaNeed4Speed6's Avatar
GotaNeed4Speed6
Default Valve Help!!!
hey guys
i need some help... i have a 1997 acura integra ls... i just wanted to know if anyone knew the valve lash timing fo the car, and if so what is it. Also if you have any detailed pictures that would be great!
Thanks!
Old 11-22-2005 | 12:24 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Check out the how-to on www.c-speedracing.com.
The writeup is for a B18C, but it is pretty much the same procedure. The lash should be stated on the underside of the hood.
Old 11-22-2005 | 06:00 PM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
I'd also check out this tutorial...I used it to do mine, and read the above-mentioned article, and I, personally, found this one to be a bit more clear, although the other one certainly isn't wrong.
good luck!
