Throttle cable for upgraded IM
Old 11-09-2005 | 05:47 AM
rugsr's Avatar
rugsr
How do my taillights look
Default Throttle cable for upgraded IM
upgraded my IM with a skunk2 IM and only thing i didnt do was the ITR cable. anyone done this yet? im sure its been done here a lot but 1. how hard is it, 2. found them new on ebay for 25 bux, is it worth it or should i go look in the yards. thanks. picks would help too.
Old 11-09-2005 | 05:53 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
bump, cause i think eventually i'd like to put the ls/itr throttle cable on my setup too
Old 11-09-2005 | 08:14 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have the LS pulley and ITR throttle cable ready when my Skunk2 manifold goes in in two weeks. I'll keep you guys updated when it goes in if there is no one else to let you know.
Old 11-09-2005 | 08:29 AM
1turbodc2's Avatar
1turbodc2
got boost?
on my skunk2 intake i just reused my gsr throttle cable, the only thing i bought was the ls/type R throttle cable bracket and it worked perfect!
Old 11-09-2005 | 08:31 AM
Provocateur
On permanent hiatus
I don't know about perfect.
It isn't perfect, but it will work.
Old 11-09-2005 | 08:53 AM
1turbodc2's Avatar
1turbodc2
got boost?
well seeing how i have had it like that for a long time, and it dosen't effect anything as far as performance or functionality i would say it works perfect, it may not look as pretty but i don't think that should constitute it not working perfectly fine
Old 11-09-2005 | 09:45 AM
Provocateur
On permanent hiatus
Yes, but you have to admit that your throttle doesn't feel the same as my car. I am sure that if you got the right throttle cable and throttle pulley, it would feel the same.
Old 11-09-2005 | 10:00 AM
1turbodc2's Avatar
1turbodc2
got boost?
well see in two weeks when we do your car ahahahha, if it turns out good i will change that pulley, if there is some fuctionality and performance difference
Old 11-09-2005 | 10:01 AM
Provocateur
On permanent hiatus
Yeah, it looks promising.
Are you not going to change the throttle cable?
Old 11-09-2005 | 10:48 AM
1turbodc2's Avatar
1turbodc2
got boost?
no i will change that as well!
