Manual To Power Windows 90-93 Teg
Old 10-18-2005 | 08:02 PM
DA808TWITCH's Avatar
DA808TWITCH
Default Manual To Power Windows 90-93 Teg
I have a 90 Integra Hatch, with stupid manual windows and manual locks. I just purchased two LS or GS-R doors that came with the whole door, windows, side mirrors, switches, and interior door panel. The only thing that was missing was the wire harness that plugs into the door and runs into the car to power it.
Do I need this wire harness? And can this conversion be possible? Just because even though I got the wire harness from the door to the car, where am I supposed to plug it in my RS?
Thank You Guys for all your help!
Old 10-18-2005 | 08:03 PM
Integral's Avatar
Integral
Nightmare Motorsports
hmmm not to sure about this one personally, but it can probably be done...
Old 10-18-2005 | 08:07 PM
DA808TWITCH
I heard that this is the place to come when everyone else say NO.
Old 10-18-2005 | 09:09 PM
DA808TWITCH
Please Help!
Old 10-19-2005 | 04:53 PM
ACT I's Avatar
ACT I
if u get please let me know
Old 10-19-2005 | 06:07 PM
DA808TWITCH
Is this even possible? Has anyone even done it before?
Old 10-19-2005 | 08:47 PM
whoaitslen2's Avatar
whoaitslen2
hermit
Ive done it to my 90. I cheated and used 93 ls doors, 93 ls interior wiring harness, and 93 ls fuse box. All just plugged right up.
Youll still need a p/w relay, fuse, and extra 10ga wire if you want to rig it up using your existing harness.
Theres a black plug under the drivers side carpet in front of the trunk release. It has 2 rows of slots. Youll need to use to distribute power and grounds to your door switches. Its already pre grounded to the chassis using black wires. Not sure if it has a yellow wire running to power though.
I dont know the exact wiring schematics but it can be found in a haynes or helms manual. Ill try and get pics up of what you need to wire.
Old 10-20-2005 | 04:46 AM
DA808TWITCH
Thanks man for all your help. As I was looking at my doors today, I noticed a fat wire harness running from inside my car into the door. Why would I need all those wires in my door if I have NO power running to them what so ever....I don't even have a speaker in the door.
Anyways, I just want to know if I can get the LS doors that I bought, and plug the existing wire harness (Thats plugged into my old door) and plug it into the LS door, and the power windows, locks, and speaker will work?
Thanks
Old 10-20-2005 | 08:52 PM
DA808TWITCH
Bump
Old 10-21-2005 | 12:15 AM
whoaitslen2
hermit
Check you harness from the fuse box the the doors. If there are 3 fat blue wires (blue/black, blue/yellow, bluegreen) that go from the doors to a black plug under the carpet it may be pre wired for power windows. Also check if you have a fuse and relay for power windows in your fuse box.
The 93 doors should be pre wired for grounds, speakers, p.mirrors, and p.windows.
