Cylinder head bolt
Old 10-19-2005 | 09:23 PM
4sd4dr's Avatar
4sd4dr
if its a stock rebuild, its not worth getting studs. but then again, they are probably cheaper than OEM bolts.
Pull the head off, run to parts store, get a tap for the threads and clean em out.
Old 10-19-2005 | 10:19 PM
dubcac's Avatar
dubcac
I
He already did that, and he can thread the head bolts into the block while the head is off...so that won't solve the problem.
Old 10-19-2005 | 10:25 PM
brewerdude's Avatar
brewerdude
OEM head bolts from the Acura dealership are $10 each, and the arp studs are $12 each + shipping, so they are a little more. And if that means not replacing the block, they're more than worth it.
Old 10-19-2005 | 10:30 PM
brewerdude's Avatar
brewerdude
Oneother thing...
Getting a tap isn't just a "run to the store". It took a couple of visits and many calls to various machine and cutting tool shops (not to mention a 40 mile drive across town) the tap you need for these bolts is an M11 x 1.5, which, I've learned in this little escapade, is a very non-standard size.
Old 10-20-2005 | 03:32 PM
4sd4dr's Avatar
4sd4dr
Originally Posted by brewerdude
Oneother thing...
Oh, well I ran to I believe it was called Cummins tools or something and got the tap I needed.
