a couple probs on 01 GS-R
Old 10-11-2005 | 06:07 AM
Ithinkyourlost's Avatar
Ithinkyourlost
2001 GS-R
Default a couple probs on 01 GS-R
Ok a question for other owners, do you have a problem shifting into 1st? i can only shift into first like when im almost stopped, its a real pain in the ass when im trying to autocross. If there is a problem, what can i do to fix it?
Also, i think im also losing hydrolic fluid since occasionally my clutch sticks back towards the firewall and i have to pull it back, what do i need to do there? just fill the hydrolic fluid up every now and then?
thanks ahead of time for the help.
Old 10-11-2005 | 06:32 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
to help you with you first question. hondas have a sort of lock mechanism to prevent from shifting into first if you're going above...say...5 mph. its sucks, but i dont know any way to override that.
Old 10-11-2005 | 07:32 AM
Ithinkyourlost
2001 GS-R
ok thats cool, at least its not a problem with the transmission or anything, thanks for the answer
Old 10-11-2005 | 08:21 AM
94civicEX's Avatar
94civicEX
I got worms.
Best way to work with it is to rev-match the gear, which I don't really recommend doing, you'll be fine in second.
When you're starting off, if it won't go into gear the first time, don't push it into gear, just let off the clutch and push it back in and try again. Just something to get used to.
Although, if you're having clutch issues, it could be that the clutch isn't engaging.
99 Integra GSR
06 TSX
duck squad member #00003
Old 10-11-2005 | 08:24 AM
LT's Avatar
LT
The deer had to die!
actually joe, the max speed is 15mph...you need to do some rev-matching to spin up the locking ring
if you're losing hydraulic fluid, first check the slave cylinder for any signs of leakage. then check around the clutch master cylinder and finally around the clutch pedal piston that goes from the cabin through the firewall. usually it'll leak there and you can see the stain in the carpet.
Old 10-11-2005 | 08:30 AM
sherwood's Avatar
sherwood
I missed Sean
yeah, i used to notice that in my dc2 and ir really pissed me off, it's normal, and yes it can get annoying.
Old 10-12-2005 | 05:05 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Don't granny shift and double clutch. Works for Vin Diesel while drag racing, wgere it has no place, so it should work on a racetrack. LOL
Old 10-12-2005 | 08:02 AM
Philip_Freda's Avatar
Philip_Freda
I want an NSX
could be a synchronizer prob, I've seen it on a 94 LS. Try rev matching as previously posted
Old 10-12-2005 | 06:47 PM
Ithinkyourlost
2001 GS-R
found the leak, two bolts on/near the slave cylinder, i might need to take it to the shop cause i bleed the hydrolic fluid out and put more in, but i think those two bolts have to be replaced, and thats not for me to do, thanks guys.
Old 10-12-2005 | 06:48 PM
94civicEX's Avatar
94civicEX
I got worms.
It isn't the bolts, it is the slave cylinder. Replace it.
99 Integra GSR
06 TSX
