so i want to remove my power steering
Old 09-23-2005 | 04:45 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Default so i want to remove my power steering
can somebody tell me how its done while still keeping the power rack? is the power rack strong enough if i used that? i just want to know exactly how its done because im confused.
Old 09-23-2005 | 05:42 PM
Takumi Fujiwara's Avatar
Takumi Fujiwara
I'm sure it's been covered... you want to remove the 2 lines that come off the rack, find a fitting for one of them because it doesn't have have... loops the lines with a breather tank and your'e golden.
There are other ways to attach the breather, but this is the easiest way.
Old 09-23-2005 | 05:44 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
can someone show me pictures of how they set theirs up? thanks takumi!
Old 09-23-2005 | 07:22 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
ill help you come to clinton
Old 09-24-2005 | 06:03 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
ok i just need some time on my hands first
Old 09-24-2005 | 07:17 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Ok... so do it. Take that shit off mang!
Just kidding. I wouldn't know exactly how to do either. I am sure that my admitting my ignorance on the topic will inspire some young grasshopper to give you a more thorough write up.
Good luck.
Old 09-24-2005 | 09:17 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Good luck.
haha i do that type of whoring also in threads that i dont know shit about and want to learn.
Old 09-24-2005 | 12:00 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Bear in mind that the steering effort at low speed will be considerably higher.
If you've got 205 section tires on the front, parallel parking is going to be interesting. :chuckles:
I considered doing this for a while on the DC4. While I haven't found a decent writeup with part numbers and such, the basics are pretty simple.
Remove the PS pump and drain the system. Don't dump the fluid down the drain or on the ground; recycle it if at all possible or dispose of it responsibly.
Then with the pump removed, either loop one of the hard lines so that both ends of one line plug both ports in the rack, or buy a pair of threaded plugs to do the job.
(I think it's an AN-6 fitting, but take a PS line with you to be sure.)
Lastly, you'll have to experiment with belt lengths to maintain proper tension after the PS pump is no longer around. Again, I haven't found a write-up that includes a part # for the proper replacement belt.
A word of caution: While it's tempting to just unplug the pump hoses and drain the system, don't let that pump rotate without fluid. It will burn up the seals in a heartbeat because it relies on the fluid for lubrication and cooling.
Old 09-24-2005 | 02:20 PM
Brar's Avatar
Brar
y do u want to remove? turbo?
Old 09-24-2005 | 03:36 PM
FooD2000's Avatar
FooD2000
Still Water
All in the name of weight reduction?
