Difference between '90 and '92 and '94 models ?
Old 09-21-2005 | 03:37 PM
sherwood's Avatar
sherwood
I missed Sean
Originally Posted by TheOtherDave™
https://www.honda-acura.net/forums/s...d.php?t=179419
Every last numdane detail on each generation of the Integra is in that thread.
After 1990, The ZC16 1.6L 16V four was replaced by the B18A (1.8L DOHC I-4) in the RS/LS/GS, and in 1992-93, the GSR used the B17A.
From 1994 onto 2001, the RS/LS/GS models moved on to the B18B1 (again 1.8L, but slightly higher compression ratio, slightly more agressive cams). And the 94-01 GSR featured the B18C1, the marginally higher-displacement successor to the B17A.
The suspension design changed in 1994, but the rest of the gory details are in the link I've posted above.
fixed h:
Old 09-21-2005 | 03:53 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by sherwood
fixed h:
Damn you and your eagle eye. :squint:
h:
Old 09-21-2005 | 04:40 PM
newtohondas's Avatar
newtohondas
h:
Yea so when I was first trying to find what engine this teg had I figured it'd be right on the side of the block where the trans hooks up because that is where it is on my sr20det so I cleaned up the engine a little bit just a minute ago and it does say B18A1
