damn abs light is on my 94' acura intege Ls.
Old 09-03-2005 | 04:06 PM
nemesis2's Avatar
nemesis2
Default damn abs light is on my 94' acura intege Ls.
uh! my abs light has been on for some time now, i would say about 3 months.
I tried fixing it my self..... I put the car on a jack and was spinning the wheels to see which one would set the abs light off. So i found out that the right rear was. Thinking that the sensor was bad I got the abs sensor replaced{RR}. Man the light did'nt go away. I also replaced the master cylinder and had the abs pump looked at too. Hey! if anybody knows anything else or any suggestions please pass it down.
Thanks alot!
Old 09-03-2005 | 04:40 PM
teggyls's Avatar
teggyls
J-villan
check your abs codes
Old 09-03-2005 | 06:30 PM
raul95020's Avatar
raul95020
Shyster_One
Thanks alot!
EVERYTIHNG MIGHT BE FIXED NOW , U MIGHT JUST HAVE TO GO AND HAVE THEM RESET THE WARNING LIGHT.
Old 09-03-2005 | 08:26 PM
nemesis2's Avatar
nemesis2
Hey! guys thanx alot for your suggestions. But I still have not so good Question, where do I have to take the car to reset the warning light?.... the dealer or is it something that I could fix myself? if so please share your ideas.
Old 09-04-2005 | 12:46 PM
teggyls's Avatar
teggyls
J-villan
you can take the negative cable off the battery for 10 minutes or take out the 7.5 hazard fuse for 10 minutes. that fuse is in the engine bay fuse box
