just bought a Teggy..
Old 07-01-2005 | 09:33 PM
88teggy's Avatar
88teggy
Default just bought a Teggy..
i bought one tonight an 88... and i just replaced the wires and plugs. and still at rpms miss.... and the rpm gauge flex's... any idea... and somone broke in the car and stole the radio.. how many contors should there be??? because i am trying to install my headunit.. "new to honda" im used to saturns.... i wanna make it fast =P it has a twin cam... but i need to fix it first...... anyshake downs? thanks!!!!!!!
Old 07-01-2005 | 09:36 PM
trextegra's Avatar
trextegra
97 Acura Integra LS 3DR
save ur money man that thing isnt worth it but as far as the rpms check ur dist. cap and rotor also u could have a bad dist. after all it is 17 years old. as far as the head unit juz go down to walmart and grad a wire harness and installation kit. makes the job really easy
Old 07-01-2005 | 09:41 PM
88teggy's Avatar
88teggy
what i got..... but someone BROKE into the car and yanked it i think... i see one concter... and the plug i have has two.... and im gonna waste every dime on it has low ass miles... just been sitting for a while
Old 07-01-2005 | 09:45 PM
trextegra's Avatar
trextegra
im not trin to rag on ur ride man its juz a really old car with small engines juz sayin you gotta do a lot of work to em like an engine swap or sumin. and back to the radio if they juz ripped it out u can proly juz rewire it its not to hard juz run new wires to ur speaker from the new deck and for the power supply juz start ur car and use a voltage tester to see what ur constant power and your turn on lead
Old 07-01-2005 | 09:47 PM
trextegra's Avatar
trextegra
what's the year range for the connecter you have the adapter that is because before i rewired my whole system i had a connector in their and it had two but i only needed to use one the one i had was disided to work with two different connector this might be the same with urs dont kno much bout it from the gen 1 tho
Old 07-01-2005 | 09:52 PM
trextegra's Avatar
trextegra
i think the one i had was all hondas 86+ so they very well be the same
Old 07-01-2005 | 09:58 PM
trextegra's Avatar
trextegra
try and hook it up see if it works im pretty sure most hondas only have one harness do u have any wires that are ripped and broken in the dash if not juz hook that bad boy up and enjoy can u get a pic for me
Old 07-01-2005 | 10:12 PM
trextegra's Avatar
trextegra
check this out found it in another in an accord forum should be helpful to u if that harness doesnt work out http://installdr.com/Harnesses/HA-Wiring.pdf
Old 07-02-2005 | 03:04 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
welcome to han and the integra forum
