integra fans arent workin
I just went through the same headache.
1. check to make sure you have coolant in yr radiator first - if low then u have a leak so look at all possible areas for leaks, hoses, drain plug, bleed plug, and gaskets. Do you smell anitfreeze? you should see dried A/F somewhere if you have a leak. If your level of A/F is low the fan switch will not know your car is in need of the fans. Also try seeing if you can start the with with your AC on. If the work then your fans are fine and it could be the switch (~$50)
If no leak then do the 2 test I attached for you.
i think i have a couple of g2 fans layin around if you find that you need to replace them, let me know.
not to insult your intelligence but make sure that they are a. plugged in and b. getting power (use a test light) also check your fuses.
hey none taken... i just bought the car from my brother.... so i have alot of stuff to check and i just need a place to start you know... i appreciate the help i will look into all that here now... thanks!
Have you checked the Accessory Relay Switches...There is 2 of them...One for each Fan. The dealer sold them to me for $49.99..but I had a buddy of mine give me a few extra at a discount. I can take a picture if you would like..
B
B
