integra fuel filer
Old 05-09-2005 | 08:25 PM
pinkys43's Avatar
pinkys43
Default integra fuel filer
Where does a fuel filter exist on a 2000 gsr. please add pics if you know
Old 05-09-2005 | 08:59 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
searching owns:
https://www.honda-acura.net/forums/s...ht=fuel+filter
Old 05-10-2005 | 04:31 PM
Tobra's Avatar
Tobra
Tis a dealer part, will come with new washers as I recall, you need to release the pressure from the system, and keep in mind there will be some fuel in the lines, have a towel and fire extinguisher handy
Old 05-10-2005 | 04:42 PM
orangebarius's Avatar
orangebarius
u can get aftermarket ones at a local auto parts store. u dont need to go wasting money at acura. ive used aftermarket ones from purolator and they work just fine. theyre around $30.
Old 05-10-2005 | 05:14 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
The filter from the dealer is a little over 20 bills and that would be the best way to go. Pop the cap off the gas outlet, undo the top and botton 12mm I believe nuts and your good to go. Just have a towel or rag stuffed under what you are undoing, there will be a little bit of fuel but nothing major. Before you break the top nut though, draw a line w/a marker so you know when to stop tightening, there is a fuel hole that needs to line up. Piece of cake, good luck!!!
Old 05-10-2005 | 05:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just don't short circuit the battery with the wrench or you will need that fire extinguisher for sure. A new filter (with washers) is about $30 from the dealer, so just shell out the money for trusted quality. Also the hole doesn't need to line up in the bolt. If you take a look at the banjo fitting, the hole can be anywhere along the fitting and still allow fuel to go through it.
Old 05-10-2005 | 05:43 PM
FooD2000's Avatar
FooD2000
Still Water
How often do you change the fuel filteR?
Old 05-10-2005 | 05:53 PM
orangebarius
i do it every tune up, so every 30000 miles, but u could do it every 60000 also.
Old 05-11-2005 | 04:59 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I wasn't sure about that, so that is what I did to make sure it lined back up. Better safe that sorry.
