Painting Body Mouldings
Originally Posted by rebeld
r u talking about the sill plates when u open the door?
Originally Posted by 94ntegls
go to www.cardomain.com/id/canimp83, the first picture on the page is what I am talking about painting and the stuff is highlighted in yelllow. The top piece is the thing that I am talking about. Can I just yank this off? (the top piece) cause it looks like its just held on with double sided tape or glue or something.
Originally Posted by c_rogue69
I wouldn't recommend just "Yanking" the moldings off. Even if they were just held on with double sided tape..."yanking" them off risks snapping them.
check out the article on team-integra.net. i did mine and it worked perfectly. take them off ur car, its easier this way. remove ur door panels to take the ones off the door. then the ones on the rear quarter panel, pry off wit a screwdriver carefully. work on one side then pop off the rest. DO NOT bend these because the creases will not go away. take ur time and use caution not to bend them. u sand, then use adhesion promotor, then prime, then paint, then clear coat. this is the best way for them to match ur car perfectly.
hey c_rogue69, have you done this before?
If you have got anymore pointers?
if u want a nice look buy a weldin kit from home depot get some sheet metal, air compessor with sandin and grinding head, take some sheet metal cut it to the size of the gap from the moldings, weld it on then grind down. sand doors down and prime and paint boom better lookin shaved doors
