BREAK indicator in the dashboard is always ON
Old 03-19-2005 | 01:15 PM
sacikumar's Avatar
sacikumar
Default BREAK indicator in the dashboard is always ON
Hi,
Mine is 99 2D HBK
If I park the car outside all night in cold & when I start the car in the morning
the BREAK indicator (red) is ON for probably until the car runs 10-15 minutes.
Don't know why. Please let me know if you ahve experianced the same
problem & how to fix it.
Thanks in Advance.
Saci.
Old 03-19-2005 | 01:28 PM
newgsrdriver's Avatar
newgsrdriver
Cmon man.
If it was on all the time, dont you think you would be staring at it enough to know its spelled BRAKE not BREAK. Sorry, pet peeve of mine.
Check your fluid level. If its ok, it most likely is the sensor underneath the reservoir cap. Replace cap, light off.
Old 03-19-2005 | 02:01 PM
carta79's Avatar
carta79
Life after death
I used to have this problem when I first got my Integra. Check your fluid level, it might be to low. If the fluid level is fine look for accumulated sediment inside of the strainer. Make sure no dirt or foreign matter is allowed to contaminate the brake fluid.
The strainer may not be letting the cap vent properly, causing the fluid level to change. Check for blockage of the vent holes on the reservoir cap.
Old 03-19-2005 | 06:03 PM
OilCanBoyd's Avatar
OilCanBoyd
This happens to me all the time. We are talking about the emergency brake light right? Same thing when its cold on my 98 GSR
Also in really cold temps when I start the car up it makes and awful whining noise.
carta are you aware of any articles or FAQ on this. I'm not familiar with your terms. I'm new to this. Thanks
Old 03-19-2005 | 07:28 PM
carta79's Avatar
carta79
Life after death
What terms are you not familiar with? To sum it up the problem is most likely low brake fluid or a faulty sensor underneath the reservoir cap, already stated by newgsrdriver.
I believe that outside temperature may be a factor as well. When my brake light came on in the past, it was because my brake fluid level was low during the winter months. I never got this indicator light during the summer months.
As far as a FAQ or article I don't know of any. I did find a technical service bulletin on this issue here . Bulletin Number: 03029
Also here's a thread on team-integra which further compliments this post.
Click here
I'm familiar with the "whining noise" you describe as well. All I can say for that is ever since I took the powersteering off my Integra the noise has stopped. I doubt that was coincidence. It's possible that cold temperature could stiffen the belts causing them to whine.
Old 03-21-2005 | 12:44 PM
sacikumar's Avatar
sacikumar
Default New to this.
Hi, I'm ALL new to the Car mechanics. Is there a online site I can refer to
check the brake fluid level, reservoir & filter with pictures. Or anyone know
where in hood I have to check this. Please help me.
Thanks, Saci.
Old 03-21-2005 | 01:44 PM
VPUPPY's Avatar
VPUPPY
Thanks, Saci.
owners manuals are a great place to learn basic stuff.
Old 03-21-2005 | 02:37 PM
94civicEX's Avatar
94civicEX
I got worms.
Mine used to do that, I just filled the fluid back up and it fixed it.
99 Integra GSR
06 TSX
duck squad member #00003
Old 03-21-2005 | 03:53 PM
carta79's Avatar
carta79
Life after death
Thanks, Saci.
Try this link, hopefully it will work for non members.
Click here
If the link doesn't work then I would recommend that you register over at team-integra.net. They have detailed articles on performance and maintenance. It's a very informative site for Integra owners.
Old 03-22-2005 | 10:24 AM
ZiGeNX77's Avatar
ZiGeNX77
Yup, almost guaranteed to work. I made a post about this on T-I.net and this is what I did to get rid of it.
