LS TURBO vs. GSR TURBO
Old 03-15-2005 | 02:18 PM
civicandtegra's Avatar
civicandtegra
i have talked to a guy who owns a shop around me and he has a type-r,
type-r block, si head 3angle, block bored out to 2.02, 7gs in custom cams, a blow head and a new 1, full rebuilt internals, and a turbonetics snail that could kill godzilla, and a ton of money in a rollcage 19gal fuel cell, lsd and crazy gear setup and he just hit 650hp, he has spent 40k on the whole thing so im not sure about making a safe 500+ hp for 10gs, i would like to see it if u do it.
i dont suggest buying a huge turbo straight out cuz i have seen way too many bottomends blown to sh*t
Old 03-15-2005 | 04:37 PM
jr_kbad's Avatar
jr_kbad
well for the 10G's i plan on boring out the motor, sleeves, pistons, rods, head gasket, cams, camshaft, and the turbo peices...i'm comfortable on dumping 10-12 G's on the motor and turbo alone.
Old 03-15-2005 | 04:53 PM
dubcac's Avatar
dubcac
I
Originally Posted by LSturbo
I wasnt saying that he couldnt beat me. all I was saying is 213 w/hp is low for 8 psi.
Sorry I didn't make it clear, but I was referring to the thread starter and not you.
Old 03-16-2005 | 01:32 PM
VTEC763's Avatar
VTEC763
Originally Posted by jr_kbad
just a quick question on the ls turbo vs gsr turbo. In one year i get my bonus and was planing on dumping 10Gs on the engine and turbo buildup. I currently have a LS motor and was thinking of swapping for a GSR motor. I was going to bore out the b18 and want to reach 500+ horsepower. IF i did the exact same thing to both motors will the number be identical or would the gsr motor exceed the ls? I mean at 20 psi + will the difference be enough to make a gsr swap warrented?
stroke it to 2.0/b20 or just get a b20 block with gsr or type r head n build engine n turbo frm there...easy power right there if u go wit a b20/crv block with low compression piston n use gsr or type r internals you'll be fine n you'll save alot more money
Old 03-16-2005 | 01:33 PM
VTEC763's Avatar
VTEC763
once your vtec kicks in n if u knows how to drive your gsr will take it
Old 03-16-2005 | 04:18 PM
dubcac's Avatar
dubcac
I
Resleeving the motor (which is necessary for high boost anyways) and boring to a 2 liter is much better than stroking to a 2 liter. OEM internals won't make it past 300whp...which is far lower than his 500 hp goal. Even if he has VTEC, he still won't beat an LS making 20hp more and a good bit more torque than he is...unless his car is lighter.
Old 03-16-2005 | 09:34 PM
nextphase's Avatar
nextphase
yahs thats what i thought wen i seen the numbers.. 213 at 8 lbs is kinna low... the tuner told me if i was to switch to obd1 i will easly make up for the low numbers... was told i can get into 240-250 whp range after my 2nd tuning w/ obd1
Old 03-16-2005 | 10:48 PM
hakjai's Avatar
hakjai
this could go back and forth, i guess we just have to wait until they find out, it must be nice having a brother that likes tegs as well
Old 03-20-2005 | 09:22 AM
kempr01's Avatar
kempr01
Default LS TURBO vs. GSR TURBO
He can have more hp and torque but if you are a better driver you should be able to take him.
Old 03-20-2005 | 09:36 AM
B18C3GSR's Avatar
B18C3GSR
Keep in mind that your GSR has that close ratio 5 speed. If you can master that close ratio then Im sure you can handle it.
