Question about Flywheel's
Old 03-01-2005 | 10:50 PM
jjang's Avatar
jjang
not my thread..apologies..but i must ask..my friend has a lightened flywheel on a stock clutch but says its the best upgrade he has done yet..is it bad to get a lightened flywheel with a stock clutch if the stock clutch is still going strong? i was considering a clutch/flywheel upgrade but wasnt sure if i wanted to spend the extra $ on a new clutch if the one i have now is fine... daily driver..
Old 03-02-2005 | 05:09 AM
mark7171's Avatar
mark7171
Hooligan on a Holiday
the factory disk and pressure plate is good. if you have i/h/e and a light flywheel should hold like a bastard.
lightened flywheel has less negative affects than something like aftermarket cams. i dont know about the 8 lb and under,but they shouldnt be that bad either. the only really noticeable difference is the mentioned starting up a hill.
Old 03-02-2005 | 03:41 PM
dubcac's Avatar
dubcac
I
You might as well replace the clutch while you're in there doing a flywheel. The stock clutch wont last long if you're beating on it anyways.
Old 03-21-2005 | 03:01 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Just thought I would let you guys know, I decided to buy the Fidanza 7.5lb flywheel. Should be here in a few days. Also got an Exedy clutch set....
Old 03-21-2005 | 03:12 PM
teg92's Avatar
teg92
WHAT OK YEAH!
:goodjob: you installing them yourself?
Old 03-21-2005 | 05:24 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
Originally Posted by teg92
for the LS, RS, GS, and The GSR it weighs 18 pounds and the type R one weighs 15 pounds
stock GSR is 18 lbs, but i believe stock ITR flywheel is only 14 lbs
Old 03-22-2005 | 07:18 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Yeah, shouldn't be much harder than doing the clutch in my 2nd gen....
I'll let you guys know how it goes.
Old 03-28-2005 | 06:39 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Well I put in my new clutch and flywheel in. I love it! Probably one of the best mods I've done so far.
Old 03-28-2005 | 10:40 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Well I put in my new clutch and flywheel in. I love it! Probably one of the best mods I've so far.
How much you get everything for?
Old 03-28-2005 | 12:16 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
I payed $385 shipped.
