Vtec not that loud
Originally Posted by LT6916
do you really want it that loud? stock intake? stock exhaust? the only thing that gets loud on the GSR is when the secondary butterflies open up.
But I've driven stock GSR's and you can't really tell. There isn't supposed to be a noticable difference going into VTEC with a stock GSR.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
OK. I took the Airbox off the car and noticed a huge differance in sound. Hitting 3,000rpms the engine gets louder and the vtec is really heard. Not sure why it took the airbox coming off for it to sound like a GSR should but oh well.
wire up a vtec light...its pretty easy, and its a surefire way to make sure vtec is engaging. vtec on a gsr with a stock ecu should engage at 4400 rpm, with the secondaries opening up at 5600 rpm. i drilled a small hole into the plastic right behind my shifter and put a green LED in. just splice a wire into the vtec solenoid, run it through the firewall and into the car to the LED, then run another wire from the LED for a ground. i think its kinda cool at least.
